3 members (Gdads51, 68ironhead, Peggy M), 94 guests, and 2 robots.
Topics128,118
Posts1,056,302
Members48,439
#602922 12/20/2009 8:36 PM
U
U Offline
Hi all,
Truck is home and painted. Now where the heck do I start in putting it back together? What is the secret to doing so without messing up the paint?
Thank you for the help...
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
UnklRod #602938 12/20/2009 10:43 PM
Looks great! Use lots of painters tape, go slow and have help.
Bruce
My Trucks
Stuff I Collect
darn, She's pretty!
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Modelman #603031 12/21/2009 4:04 AM
U
U Offline
Hey all,
How do you tighten painted bolts and nuts without chipping the paint off? Also, I am putting the parts back in the dash. there is paint build up on the holes. I am having troube getting the switches through the holes. How do I do that with chipping? example: heater switch, choke, throttle, radio..etc. holes...
Thank you
More pix
UnklRod #603081 12/21/2009 7:48 AM
Your trucl looks great Jon~!
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #603087 12/21/2009 8:12 AM
Jon,your truck looks amazing.
As far as the build up,do as Bruce suggests,take your time and use plenty of tape and help.
Re; the paint build up, I would be tempted to use some rolled up wet/dry sandpaper and try to open the holes up that way.
Maybe someone will chime in with a better suggestion.
More pix on Flickr.
Lots of tape and be very careful. Yes, on the sandpaper, I just touched up the bolts after tightening them, worked for me. I have not found a good way to keep the bolts from chipping. I replaced a lot of the bolts with stainless ones. My son and I did it together with some help from my wife. Definitely need a helper or two. Truck looks great, nice paint job!!!
Coach Frank
coach-frank #603250 12/21/2009 10:57 PM
Truck looks great , just take Your time , and the sandpaper rolled up works good for that paint on Your dash and for putting bolts thru any holes I got some wood rod of different sizes for that and some real fine sandpaper .
Pete
Pete52 #603333 12/22/2009 3:31 AM
U
U Offline
Great thanks everyone!
I have been very very slow on doing the work. I think I will be putting the wire harness in first to get that out of the way. Just hard to know where to start! But lots of fun doing it ahead. Is it possible to paint stainless steel? Does the paint chip down the road?
Jon
More pix
UnklRod #604201 12/25/2009 1:36 AM
Looking good Jon. You are moving right along.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
UnklRod #604705 12/27/2009 12:50 PM
Originally Posted by UnklRod
Hey all,
Thank you
I used a tapered reamer (http://www.mcmaster.com/#3018a4/=541z85) to clean the paint out the holes and ran a tap through all of the threads. Put a dab of anti-sieze on the parts that go through the holes and it should keep the bare metal from rusting.
To tighten the bolts, you may want to consider using washers and assembly lube under the bolts that thread directly into the sheet metal (otherwise tighten on the back side). The biggest problem I've had with new paint is bulging around the area of compression. Unless the new paint was baked, it's probably going to be soft for a while.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
UnklRod #604771 12/27/2009 6:49 PM
Start with the things that are hardest to get to first. That way anything like instruments that would block access won't compound your work.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Czechman #605098 12/29/2009 1:29 AM
U
U Offline
Hey all,
Thank you for the help! I see what you mean...there is a way to the assembly. I am thinking about putting the grill back in before mounting the radiator. Looks like much better access to the mounting bolts and nuts that way. I was able to get the holes cleared out and bolts are going in very well.
More pix
