1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, Truck is home and painted. Now where the heck do I start in putting it back together? What is the secret to doing so without messing up the paint? Thank you for the help... Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Looks great! Use lots of painters tape, go slow and have help.
Bruce | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hey all, How do you tighten painted bolts and nuts without chipping the paint off? Also, I am putting the parts back in the dash. there is paint build up on the holes. I am having troube getting the switches through the holes. How do I do that with chipping? example: heater switch, choke, throttle, radio..etc. holes...
Thank you 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Your trucl looks great Jon~!
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Jon,your truck looks amazing. As far as the build up,do as Bruce suggests,take your time and use plenty of tape and help. Re; the paint build up, I would be tempted to use some rolled up wet/dry sandpaper and try to open the holes up that way. Maybe someone will chime in with a better suggestion.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Lots of tape and be very careful. Yes, on the sandpaper, I just touched up the bolts after tightening them, worked for me. I have not found a good way to keep the bolts from chipping. I replaced a lot of the bolts with stainless ones. My son and I did it together with some help from my wife. Definitely need a helper or two. Truck looks great, nice paint job!!! Coach Frank | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Truck looks great , just take Your time , and the sandpaper rolled up works good for that paint on Your dash and for putting bolts thru any holes I got some wood rod of different sizes for that and some real fine sandpaper .
Pete | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Great thanks everyone! I have been very very slow on doing the work. I think I will be putting the wire harness in first to get that out of the way. Just hard to know where to start! But lots of fun doing it ahead. Is it possible to paint stainless steel? Does the paint chip down the road? Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Looking good Jon. You are moving right along.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Oct 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 119 | Hey all, How do you tighten painted bolts and nuts without chipping the paint off? Also, I am putting the parts back in the dash. there is paint build up on the holes. I am having troube getting the switches through the holes. How do I do that with chipping? example: heater switch, choke, throttle, radio..etc. holes...
Thank you I used a tapered reamer ( http://www.mcmaster.com/#3018a4/=541z85) to clean the paint out the holes and ran a tap through all of the threads. Put a dab of anti-sieze on the parts that go through the holes and it should keep the bare metal from rusting. To tighten the bolts, you may want to consider using washers and assembly lube under the bolts that thread directly into the sheet metal (otherwise tighten on the back side). The biggest problem I've had with new paint is bulging around the area of compression. Unless the new paint was baked, it's probably going to be soft for a while. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I think I will be putting the wire harness in first to get that out of the way. Just hard to know where to start! Start with the things that are hardest to get to first. That way anything like instruments that would block access won't compound your work. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hey all, Thank you for the help! I see what you mean...there is a way to the assembly. I am thinking about putting the grill back in before mounting the radiator. Looks like much better access to the mounting bolts and nuts that way. I was able to get the holes cleared out and bolts are going in very well. 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | |
