| | | Forums66 Topics128,283 Posts1,058,521 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60259 05/09/2006 2:29 AM | Joined: Jul 2005 Posts: 12 Junior Member | | Junior Member Joined: Jul 2005 Posts: 12 | Had some more time to look at the 235 in my Dad's 3100, and it looks like our guess was correct. It would appear that one of the halves of a split bearing rode up on the other, locking the crank in place, and causing this truck to have not been run for the past 18 years! Has anyone else run into this before? How can I fix the situation. Here's a few pics for you.
First off, we have the front half bearing compared to the half that the oil sump bolts onto (that one is the third from the front).
http://www.king-nerd.com/dood/images/minigal/1953%20Chevy%20project%20truck/3.%20Tearing%20down%20some%20of%20the%20engine,%205-08-06/thumbs/tn_med_100_1993.jpg
Next up, you can see where the bearing race is no longer connected to the thing (more technical term?):
http://www.king-nerd.com/dood/images/minigal/1953%20Chevy%20project%20truck/3.%20Tearing%20down%20some%20of%20the%20engine,%205-08-06/thumbs/tn_med_100_1995.jpg
Here you see the split bearing still hanging onto the crankshaft, even after having to pry the other bit off...
http://www.king-nerd.com/dood/images/minigal/1953%20Chevy%20project%20truck/3.%20Tearing%20down%20some%20of%20the%20engine,%205-08-06/thumbs/tn_med_100_2000.jpg
Is it normal for this bearing to have lips on both sides? It seems that this wedged it in the crank:
http://www.king-nerd.com/dood/images/minigal/1953%20Chevy%20project%20truck/3.%20Tearing%20down%20some%20of%20the%20engine,%205-08-06/thumbs/tn_med_100_2001.jpg
The backside of the bearing (you're not usually supposed to see this!):
http://www.king-nerd.com/dood/images/minigal/1953%20Chevy%20project%20truck/3.%20Tearing%20down%20some%20of%20the%20engine,%205-08-06/thumbs/tn_med_100_2006.jpg
The part of the bearing that the crank actually rests on:
http://www.king-nerd.com/dood/images/minigal/1953%20Chevy%20project%20truck/3.%20Tearing%20down%20some%20of%20the%20engine,%205-08-06/thumbs/tn_med_100_2007.jpg
If you look closely, you can see that the top half of the bearing has spun slightly and is hanging out of its channel. Attempts to tap it back in were unsuccessful...:
http://www.king-nerd.com/dood/images/minigal/1953%20Chevy%20project%20truck/3.%20Tearing%20down%20some%20of%20the%20engine,%205-08-06/thumbs/tn_med_100_2011.jpg
A cleaner shot of the above:
http://www.king-nerd.com/dood/images/minigal/1953%20Chevy%20project%20truck/3.%20Tearing%20down%20some%20of%20the%20engine,%205-08-06/thumbs/tn_med_100_2012.jpg
Any thoughts on how hard this situation is going to be to rectify? My dad wants to keep the truck original, but I'd rather modernize it a little... At this point, it looks like we'd have to tear the entire engine down for a cleaning anyway... | | |
#60260 05/09/2006 3:55 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | A total rebuild is about the only cure for that engine. The heat the crankshaft took may have trashed it beyond repair, if the rust hasn't. I would look for a 54 or newer 235 or even a 261 and upgrade your truck to full pressure oiling. Scott | | |
#60261 05/09/2006 12:25 PM | Joined: Jul 2005 Posts: 12 Junior Member | | Junior Member Joined: Jul 2005 Posts: 12 | It is a '54 or newer engine, according to the code stamped on the block. Obviously not the original engine for this truck... My thoughts were that this thing was probably trashed anyway, from a logistical standpoint. I'm sure there's ways to get it running again, but the time spent wouldn't be worth it! | | |
#60262 05/09/2006 1:45 PM | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | This motor is a full pressure motor, or at least the rod caps are from one. There are no dippers on the rods.
It looks like there has been some type of massive oiling failure. That is the only way to explain the rust covered rod and crankshaft at the left.
One of the center bearing assemblies has thrust surfaces front and back and this appears to be the bearing.
This block could be very expensive to fix including align boring which would be madatory. I would maybe salvage the head and let the rest go. | | |
#60263 05/09/2006 2:01 PM | Joined: Jul 2005 Posts: 12 Junior Member | | Junior Member Joined: Jul 2005 Posts: 12 | More confirmation, thanks. The rust, I believe, is just from the engine sitting with the oil pan off for, oh, the last 6 or 7 years... | | |
#60264 05/10/2006 1:09 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | The one you say turned is the thrust bearing, thats the two lips on the side of the bearing. That engine is probably just seized up from sitting with the pan off... even sitting with the pan on and in a shed sometimes they will seize sitting that long, or was it seized when it was parked did you say..?? regardless it doesnt look like it turned, the top half of the block on the main bearing has like a pin dowel that goes down to hold the bearing in place, kinda rare to turn a main bearing on one of those... if you want to save it.. just tear it down and take to machine shop and have them look at it,, they will tell you if it needs bored and crank turned. The main bearings can be shimmed also. easiest way is to let the machine shop check it after its tore down... id almost bet some of the rings are seized also....or other rod caps even...yeah now i see ya say it was parked locked up....just guessing from just rust on the thrust bearing,,tells me it got hot, cause it appears maybe it rusted more than the others? if it was hot,, was probably oil problem , but it dont look like it turned,, anyway like i say tear it down and have it checked, if the crank isnt scored it can be polished or turned. the bores need checked anyway sitting that long.....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
