1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 9 | I am in the process of boxing the frame on my '38. I was wondering what size bolts mount the cab and bed to the frame. I need to weld cage nuts on and no distributors will tell me what size the bolts are that come in their cab mount kits. Can anyone tell me?
Every time you use it is one less time it's going to work...SO USE IT UP!
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I couldn't locate anything in a master parts catalog, but since you are modifying the chassis why not use whatever will work for you?
Drew
| | | | | Joined: Dec 2009 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 9 | I guess I would just like to make sure that I am in the ball park with the correct size. I also still plan on using a stock cab mount system. I may just end up cutting ovals in the boxing plates anyway. On a side note, I had a hard time finding floating weld retainer nuts (basically strong cage nuts) that would work for this application. Most people who sell them do so in bulk. I e-mailed the people at Ohio Nut and Bolt Company and told them the situation. They were kind enough to ship me enough for my project as a sample. If any of you run a business where you may need fasteners, I suggest using them, they were fantastic. And I am in no way affiliated with them, I am just an idiot in a one car garage. Eric
| | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | My '56 GMC uses two 1/2" bolts with three grade marks and two 3/8" also with three marks. I think the 1/2 " ones are on the front of the floor, the smaller under seat/gas tank. Hope this helps.
Dave
Well, my time went so quickly, I went lickety-splitly Out to my ol' 55. As I pulled away slowly, Feelin' so holy, God knows, I was feelin' alive..... Tom Waits, Ol' 55
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Both my '48 and '53 uses 1/2" diameter in front and 3/8" diameter in rear
| | | | | Joined: Dec 2009 Posts: 9 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 9 | Thanks guys, I appreciate the help.
