| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 78 | Would it be ok to put he front end up on wheel dollies or should it be on a trailer. I have a 1954 3600 4 speed. distance to home is 130 miles.
thanks for the help
tony | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | What do you mean by "wheel dollies"? Your use of the plural confuses me.
I have used a dolly to move a truck before and personally much prefer a trailer.
Some states have laws governing what you can tow and what you can not. In my state the '54 would need to be licensed if towed on a dolly.
Also in my state there is a limit on the weight of a towed load if it does not have brakes, I believe that is 3000 pounds and your 3600 exceeds that by about 1000 pounds.
I don't know what the rules are in Missouri but you probably should before starting out.
Any kind of dolly means you don't have brakes on the load, and therefore your tow vehicle will be stopping everything. Is the GVWR rating of your tow vehicle at least 4000 pounds more than it weighs?
A 1/2-ton pickup won't have adequate brakes to do this safely but a 3/4-ton might.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey Tony, A lot depends on the condition of the truck, is it running? If it were me, I'd try to find a trailer. You don't know what condition the rear end is in or if the tires will hold up. If it were only a very short distance you could try the dolly.
Bruce | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | get a trailer. Dolly's suck and dont have brakes.
| | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Going that distance, most definitely use a trailer. It will save you a lot of hassle and headaches. I've been there and have towed trucks hundreds of miles with tow-bars, dollies, and trailers. Trust me, don't use anything other than a trailer.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | in missouri you only have to worry about the rules if you get caught.  i have used a trailer without brakes many times to move vehicles. i have a wrecker but still use a trailer lots of times. i have used tow dollies too. like said, a lot of it boils down to what you are using to pull it. good luck, no matter what take it a little slower and pull over and let people around if you need to. driving a little slower will make it safer no matter what method you use, just don't let anyone kill you trying to get around you! | | | | | Joined: Nov 2009 Posts: 86 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 86 | Trailer. The only smart way.
If you are looking for the adventure of a risky haul, then way out in the country where no-one can get hurt but you, haul the truck a few miles on the dolly to the trailer... But if thrills and adventure is what you are seeking, I suggest you take up bungi jumping to scratch that itch... Use a good trailer with brakes to haul your new stove bolt, and tow the trailer/stovebolt combination with something that weighs enoug so the tail wont wag the dog..
A dolly isnt much better than a tow bar... if the steering is well secured, then a tow bar and a dolly are pretty much the same... Turning puts a lot of stress on the tow joints, and on the towed-vehicle, because the "pivot point" is the whole wheel base of the truck being towed.
With a tandem axle trailer, (dont use anything less than a tandem axle trailer...) the pivot point on the turns is reduced to about 18 inches, the wheel base between the trailer axles...
The stress of turning with a dolly and a tow bar is a good enough reason... Alone... The unknown state of tires, bearings, rear-end lubrication, and all the other things mentioned by the other responses, make an overwhelming case for getting a trailer.
| | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Tony,
I sent you a P.M.
Kevin Kevin
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I have a trailer and a dolly. I don't think I would want to tow that vehicle very far on a dolly.
If you do use a dolly, KEEP YOUR SPEED DOWN! If it starts to fish tail, it is a bear to get under control. The weight of that vehicle will push the rear of the tow vehicle around like you wouldn't believe. Watch it on ALL corners too.
Don't ask us how we know these things.
Nothing like a trailer. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Don't ask us how we know these things. LOL! When I was ready to buy a tandem axle car trailer cost three to four times the price of a dolly. Having experience with both I bought a trailer and have NEVER regretted that decision or used a dolly since.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 |
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | A dolly has its place. Generally, towing a dinky car behind an RV. | | | | | Joined: Oct 2009 Posts: 20 Apprentice | | Apprentice Joined: Oct 2009 Posts: 20 | U-Haul has car/truck trailers for about $60 a day...no brakes though. Just rented one to bring my '41 home...hauled it 1,600 miles round trip and it worked like a champ.
Good luck, whatever you decide to do. | | | | | Joined: Nov 1995 Posts: 5,735 24601 | | 24601 Joined: Nov 1995 Posts: 5,735 | Good advice here, Tony -- If it isn't already a moot point, please check out the Trailering Article in the Tech Tips. Personally, after a very bad experience with a tow dolly (that *almost* ended up with the complete destruction of my '70 Chevelle SS convertible), I switched to a tow vehicle and a trailer to haul my trucks/projects/etc around -- I currently tow with a 25-foot gooseneck pulled by a Dodge Cummins 3500 dually. Congrats on your new project! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Oct 2006 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 99 | I recently rented a 7500 pound capacity trailer from u-haul and it had inertia brakes which worked well towing my '56 3/4 ton behind my '85 GMC 1 ton. They really worried about the weight of the towing vehicle. With a 6500 # curb weight and a heavy duty hitch I passed their scrutiny. The '85 is 21 feet long, which eliminated any sway. I am a big fan of trailer brakes for heavy loads. They give a great feeling of security when I feel them kick in.
Dave
Well, my time went so quickly, I went lickety-splitly Out to my ol' 55. As I pulled away slowly, Feelin' so holy, God knows, I was feelin' alive..... Tom Waits, Ol' 55
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | '85 GMC 1 ton. They really worried about the weight of the towing vehicle. With a 6500 # curb weight and a heavy duty hitch I passed their scrutiny. The '85 is 21 feet long I'm a big fan of big trucks for towing. Something like your 1-ton takes a lot of the worry out of pulling a heavy trailer.
