3 members (tclederman, TUTS 59, 1 invisible), 132 guests, and 1 robot.
Topics128,113
Posts1,056,279
Members48,439
#601628 12/16/2009 4:26 AM
1 Offline
Need to convert a WC T-5 Tranny from a Electro speedometer to analog speedometer. Can this be done?
Thanks in advance
Jeremy
http://s925.photobucket.com/home/jeremy5756/allalbums
The only dumb question... is the question you didn't ask...- Unknown
Jeremy:
I would check on inliners.org
They have extensive write-ups on T-5 conversions. I think they also cover your issue. Alternatively, there is an add on device to handle this, but it is a bit pricey from what I remember.
I hope this is helpful.
Regards,
STeve
New Orleans
1 Offline
Sclor, I read the T-5 the easy way but, i don't have a S-10 tail to swap. I might have to purchase the adapter or the cheaper route would be to purchase a NWC which has the Analog Speedometer.
Jeremy
Riding in the Passing Lane
1972 Chevy c10 Cheyenne Super
you have to change the tail housing, or use an electric to mechanical drive which is $300. however the new gauges these days are cheep for electronic input.
1 Offline
Scott, I would like to use the old face in my gauge. Would the new electronic gauge work with my current setup?
Jeremy
Apprentice
Apprentice
Just curious, what year is your t-5 and what engine are you mounting it to ?
1 Offline
Rick, I think it's out of a F@#D 1986-87 Mustang/Capri 5.0. It's bolted up to a 1984 SBC.
Jeremy
37ChevyPickup, check out the custom gauges offered by SpeedHut.comhttp://www.speedhut.com/ They are in SLC.
I had them make some custom gauges for my 57' BelAir and they did a great job. I know they make 5" gauge units too. Reasonably priced for what I got.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
if its a ford unit, I thought they changed to electric speedo's in 91, where GM changed in 89. Did you use a custom pilot bearing for the larger input shaft pilot?
