7 members (Phak1, moparguy, Chooglin, 54farmtruck, 2-Ton, GMCJammer51, WICruiser), 47 guests, and 2 robots.
Topics128,151
Posts1,057,004
Members48,460
anyoneknow the ratio? and will it fit under a '50.i want to keep the six lug when i take out the torque tube.
Most likely 3.90 to 1.
The pumpkin will bolt into your '50 1/2 ton housing.
Steve
'49 3800
'52 3600
'57 3100
It could also have a 4:10 if the 59 truck came with an OD trans. Other wise it would likely be a 3:90.
Fred
There was also a 3.36 option that, from what I understand, was used mostly on Hydra Matic trucks.
But, as mentioned, it's most likely A 3.90.
Bill Burmeister
