2 members (Roxxstar, 1955 1 Series), 298 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
anyoneknow the ratio? and will it fit under a '50.i want to keep the six lug when i take out the torque tube.
Most likely 3.90 to 1.
The pumpkin will bolt into your '50 1/2 ton housing.
Steve
'49 3800
'52 3600
'57 3100
It could also have a 4:10 if the 59 truck came with an OD trans. Other wise it would likely be a 3:90.
Fred
There was also a 3.36 option that, from what I understand, was used mostly on Hydra Matic trucks.
But, as mentioned, it's most likely A 3.90.
Bill Burmeister
