1 members (LAROKE),
155
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,196 Posts1,057,392 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60141 05/07/2006 2:01 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | What is the rope seals made of ? Those boogers are tuff to cut. I started out with a razor blade,ended up putting a edge on my pocket knife. Those fibers look like they are a cavlar material. I have read the older rope seals had asbestos in them. Whats your thoughts ?? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#60142 05/10/2006 12:16 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | use a new razor blade , when it gets dull touch one side only of blade to your bench grinder wheel it wil cause the blade to have a serried edge and work well. | | |
#60143 05/10/2006 5:09 AM | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Aren't they made out of babbit?
That's what my dad says anyhow. | | |
#60144 06/01/2006 7:35 AM | Joined: Dec 2004 Posts: 56 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 56 | From what I understand (and I don't understand much!) "babbit" referred to the soft metal linings of the piston arm that rides on the crank like a busing, and "beater" referred to how the crank picked up oil from the pan to lubricate "babbit." Hence "babbit-beater". But get another opinion. | | |
#60145 06/02/2006 12:00 AM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | Used to be asbestos I hope you weren't breathing when you cut the critter ?
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
