2 members (TexasA&M48Truck, Wayne67vert), 77 guests, and 3 robots.
Topics128,212
Posts1,057,463
Members48,471
#60141 05/07/2006 2:01 PM
What is the rope seals made of ? Those boogers are tuff to cut. I started out with a razor blade,ended up putting a edge on my pocket knife. Those fibers look like they are a cavlar material. I have read the older rope seals had asbestos in them.
Whats your thoughts ??
1951 3100 Chevrolet
#60142 05/10/2006 12:16 AM
use a new razor blade , when it gets dull touch one side only of blade to your bench grinder wheel it wil cause the blade to have a serried edge and work well.
#60143 05/10/2006 5:09 AM
Aren't they made out of babbit?
That's what my dad says anyhow.
#60144 06/01/2006 7:35 AM
From what I understand (and I don't understand much!) "babbit" referred to the soft metal linings of the piston arm that rides on the crank like a busing, and "beater" referred to how the crank picked up oil from the pan to lubricate "babbit." Hence "babbit-beater". But get another opinion.
#60145 06/02/2006 12:00 AM
Used to be asbestos I hope you weren't breathing when you cut the critter ?
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
