| | | Forums66 Topics128,122 Posts1,056,332 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Even though I am a year or two away from a running truck, I am doing some small projects to provide a diversion from the endless body prep. I have three Rochester carbs I am trying to make one good one from. It may be an exercise in futility since all three have visible gaps between the airhorn and bowl no matter what combination I put them together in. One question I cannot see answered in the archives is the differences in the power pistons. 2 of the carbs have a more solid looking piston with a tit on the end. These look like the pistons shown for a auto choke Powerglide carb. The third power piston has the longer thin rod on the end. Either one looks like it will lift the ball in the power valve. Are these power pistons interchangeable? Chuck | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have seen those thicker pistons also & it seems to me it would be defeating the purpose. These re builders put them in thinking it is more durable. If you notice every one like that has some kind of rebuild sticker or stamping, & the metal tag is gone. The tiny rod goes in & knocks the ball off the seat letting more gas go through. A thicker rod or one that blocks the hole is not right. I would use the original thin one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Thanks for the info guys. I probably should have included that these carbs I have are the 1 1/2" 235 units. I am still a little puzzled because that manual says they started using the thinner rod piston in 1953. Was the thicker solid piston used in the later 235 carbs?
Chuck | | |
