Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (1955 1 Series, farmallb, baldeagle, Dennys28, cmayna), 63 guests, and 3 robots.
Topics128,004
Posts1,055,265
Members48,418
#601029 12/14/2009 2:30 AM
Does any body sell 6-volts made so the cell caps don't leak?
joes1952 #601037 12/14/2009 2:46 AM
I do not know for sure. I'd try Tractor Supply or some farm outlet place in your area. I would think you can get a maintenance free one but can't say for sure. Maybe someone else has been there...done that.
joes1952 #601045 12/14/2009 3:26 AM
If your cell caps are leaking, the battery is either overfilled or overcharged. There should be an air gap at the top of the cell to allow for expansion, but if too much water is added, the cell will overflow. The other cause of overflow is too high a charge voltage, causing the acid to boil over. On a 6 volt, the terminal voltage on a fully charged battery with the engine running at a fast idle shouldn't be above 7.5 volts.
joes1952 #601075 12/14/2009 4:48 AM
Here is a top of the line model....Optima are all sealed I believe...they cost too!
http://www.amazon.com/Optima-Batteries-8010-044-Starting-Battery/dp/B00099HVN6
My 12 volt in my Z28 is great for turning over a high compression engine. Check local parts houses for a better price.
Hank
1951 restoration on website
http://www.hanklong.com
