5 members (cmayna, jay d, 2-Ton, 2 invisible),
44
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | Does any body sell 6-volts made so the cell caps don't leak? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I do not know for sure. I'd try Tractor Supply or some farm outlet place in your area. I would think you can get a maintenance free one but can't say for sure. Maybe someone else has been there...done that. | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | If your cell caps are leaking, the battery is either overfilled or overcharged. There should be an air gap at the top of the cell to allow for expansion, but if too much water is added, the cell will overflow. The other cause of overflow is too high a charge voltage, causing the acid to boil over. On a 6 volt, the terminal voltage on a fully charged battery with the engine running at a fast idle shouldn't be above 7.5 volts. Jerry
