| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59993 05/04/2006 12:10 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | The 1940 suburban 1/2 ton has a 4 speed with granny gear and a lever for reverse it is a non synchro transmission torque tube driveline. Is there a syncro 4 speed that will bolt in without mods? The transmission is in need of rebuild or replace. thanks for addvice | | |
#59994 05/04/2006 1:17 AM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I'm not aware of any syncro 4 speed that's a simple bolt-in. The easiest way to get a syncro transmission is to use a 39-46 three speed which has syncromesh on second and third. The only difference in appearance from the cab is no reverse lock-out on the 3 speed. | | |
#59995 05/04/2006 4:06 AM | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | I just did a swap into my 39 using an adapter plate from buffalo enterprises. I have an open rear. Maybe you could pull this off with a later 1/2 ton TT SM420 and later bellhousing with pedal mounts welded on. | | |
