0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#59993 05/04/2006 12:10 AM
The 1940 suburban 1/2 ton has a 4 speed with granny gear and a lever for reverse it is a non synchro transmission torque tube driveline. Is there a syncro 4 speed that will bolt in without mods? The transmission is in need of rebuild or replace. thanks for addvice
I'm not aware of any syncro 4 speed that's a simple bolt-in. The easiest way to get a syncro transmission is to use a 39-46 three speed which has syncromesh on second and third. The only difference in appearance from the cab is no reverse lock-out on the 3 speed.
I just did a swap into my 39 using an adapter plate from buffalo enterprises. I have an open rear. Maybe you could pull this off with a later 1/2 ton TT SM420 and later bellhousing with pedal mounts welded on.
