5 members (TUTS 59, Fannin, Phak1, Wheelie, chevyb), 284 guests, and 1 robot.
Topics128,084
Posts1,056,085
Members48,434
#59993 05/04/2006 12:10 AM
The 1940 suburban 1/2 ton has a 4 speed with granny gear and a lever for reverse it is a non synchro transmission torque tube driveline. Is there a syncro 4 speed that will bolt in without mods? The transmission is in need of rebuild or replace. thanks for addvice
I'm not aware of any syncro 4 speed that's a simple bolt-in. The easiest way to get a syncro transmission is to use a 39-46 three speed which has syncromesh on second and third. The only difference in appearance from the cab is no reverse lock-out on the 3 speed.
I just did a swap into my 39 using an adapter plate from buffalo enterprises. I have an open rear. Maybe you could pull this off with a later 1/2 ton TT SM420 and later bellhousing with pedal mounts welded on.
