3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#598971 12/07/2009 3:10 PM
I'm just putting the universal back into my 1/2 ton. I coated the whole thing with wheel bearing grease. Is this a bad idea or will it work?
It's probably not a good idea to be mixing a wheel bearing grease with a gear lube, they are two different types of lubricants. If it's not together yet I would suggest cleaning off as much of the grease as possible prior to assembly and then fill with a good 75W or 80W-90 gear lube.
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Probably won't hurt anything. The universal joint is lubed by the oil from the trans. Typicaly 90wt. I wouldn't leave a big gob of grease on it, but a little will be OK.
George
46forme #599087 12/07/2009 9:24 PM
"If it's not together yet" Too funny! I have already had the darn thing together and apart 5 times already. I'm sure one more time will not hurt. Haha...
Here is what has happened so far after installing the universal joint...
1. Realized I forgot to put the collar which bolts onto the transmission onto the axel. Removed universal, put the collar on, reinstalled universal.
3. Realized that I did not replace the gasket and seal in the collar as well as the universal cover rear cap. Removed universal, replaced gasket and seal, reinstalled universal.
4. Realized that I did not put collar gasket for between universal cover and transmission in. Removed universal, put in gasket, reinstalled universal.
5. In attempting to actually bolt universal cover collar to transmission realived that there is no way to get the collar past the transmission rear mount crossmember. Face turned red, temperature spiked, said a lot of words that I will not retype here very loudly, Threw my wrench at the wall, washed up and went inside.
6. After a couple of days of cooling down, created this post to try to avoid removing the universal anymore than 1 more time.
46 HalfTon #599099 12/07/2009 10:22 PM
That's too funny, been there done that myself. Practice truly does make perfect.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Sorry there 46, didn't realize the excercise you had gone through. I had 'differential' and not 'universal' on the brain. The grease should not be a reason to remove it "1 more time". thumbs_up
Allan
1951 GMC 1/2-ton
magfarm51 #599379 12/08/2009 6:54 PM
I usually pack my rear axle bearings with grease before assembly. I never worried about mixing the gear lube with a little grease. I'd fill it up and forget about it.
Builder #599465 12/08/2009 10:48 PM
grease is nothing more than a wax carrier for oil. Like Builder said, fill it up and forget about it.
