0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 7 New Guy | | New Guy Joined: Nov 2009 Posts: 7 | The best kit and were to buy? '52 1/2 ton longbed, 9 inch Ford rear. Thanks
Do Something, Lead, Follow, or Get Out of the Way!
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Welcome tones52! Are you asking about a kit to adapt a 9" to your stock leaf springs? | | | | | Joined: Nov 2009 Posts: 7 New Guy | | New Guy Joined: Nov 2009 Posts: 7 | The guy that I bout this pickup from had already added the rear end and mounted it on top of the original springs, witch works OK but I would like to lower it a few more inchs and add shocks to both sides.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Well, the hard work is already done then, you just need some lowering blocks (Speedway carries these, as do many other vendors) and maybe remove a rear leaf or two. Should be able to measure the shock length and take a trip to your local parts house and pick up a pair that will work for ya. | | |
