0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#598508 12/05/2009 5:55 PM
The best kit and were to buy? '52 1/2 ton longbed, 9 inch Ford rear. Thanks
Do Something, Lead, Follow, or Get Out of the Way!
Welcome tones52! Are you asking about a kit to adapt a 9" to your stock leaf springs?
The guy that I bout this pickup from had already added the rear end and mounted it on top of the original springs, witch works OK but I would like to lower it a few more inchs and add shocks to both sides.
Well, the hard work is already done then, you just need some lowering blocks (Speedway carries these, as do many other vendors) and maybe remove a rear leaf or two. Should be able to measure the shock length and take a trip to your local parts house and pick up a pair that will work for ya.
Try here for shock numbers. Length and end design will be custom to your truck, you need about 3.5" travel compression and 2" extension from ride hight.
http://www.monroe.com/catalog/documents/08_MountingLengthSheet.pdf
Joe
