0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | Hello all, I need some help, I have a 62 gmc with a 305 commercial in it, when I got it it would backfire and to get up on RPM's you would have to accelerate very very slow to engage the clutch to get it to go down the street, I figured it was the carburator as for the owner told me it was never touched, I had a professional rebuild the WW Stromburg and he said it was the first rebuild on it, I put it back on exactly as it came off and cleaning the intake and applying a skim layer of gasket sealer on both sides of the gasket to ensure no leaks,however the truck dose not want to run now, I have a fresh battery, I have good spark, to prime it I put about 2 shot glasses worth of fuel in it untill I knew the pot was full then used starting fluid, I am getting fuel in the carb. from the jet valves, fuel pump works, compression check has all cyl. at around 3 lbs. difference except 1 at 7 lbs. low, the dist. cap is new and so is rotor, wires are ok so are plugs ( I drove it home )but now not 1 cylinder tried to fire off so I'm stumped, any ideas? Thank you in advance for answers, Todd
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | basics - check the plugs, are they fouled or wet.
If it didnt run on starting fluid, you have no spark
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | He said he has good spark. So - question is - is it timed right? Check your timing while someone cranks the engine over. | | | | | Joined: Jun 2009 Posts: 42 Apprentice | | Apprentice Joined: Jun 2009 Posts: 42 | Is this the 305 V-6? Has it been rebuilt yet? It sounds like a stretched timing chain. It is causing some of the valves to not close completely before the plug fires, and may also mess with the lack of compression. Remove the distributor cap and manually turn the crank, to see how much delay [if any] there is before the rotor starts to turn. This will determine how much play is in the timing chain.
Also if we put too much gas into it, and flood the motor, we wash all the oil from the between the cylinder walls and piston rings. This causes poor or no compression, that is needed to get it to fire. Pull the dipstick and see if you can small fuel on it. If so, change the oil and filter and try again.
1965 Olds F85 wagon 1969 Olds Cutlass 1965 Falcon Van 1969 El Camino 1972 GMC 3/4T 1972 K5 Blazer 1971 C10 1976 Suburban 1978 Suburban 1930 F**d AA Stake 1989 CK3500 2WD 2000 CK3500 4WD 1953 GMC 3100
1] *Note* All drawings are subject to engineering changes at any given time without notice of: barometric pressure, wind patterns, caffiene, or written authorization of the female. 2] Cash for Clunkers: You can have my truck, after it has turned into a pile of rust in the driveway.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | this is a double posting also under 60-66 ron | | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | Yes I was advised to post here too, I am taking down every piece of advice to get it going, all advice is greatly appriciated. | | |
