10 members (Donf, Gdads51, Woogeroo, Jon G, DennisM, JoeDude, rfs56trk, Jaison, frogfarmer, Hotrod Lincoln),
164
Mod | | | Forums66 Topics128,035 Posts1,055,528 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 22 New Guy | | New Guy Joined: Aug 2004 Posts: 22 | will a late model colorado (chevy) 6 lug wheel fit a 50 chevy 3100 ? What wheels (stock)will fit? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have NOT personally tried them but one of my friend says he has some on his..... but according to most reports they will rub the tie end rod unless you use a spacer...which most folks don't recommend but some run the spacers with no problems.
I think pickup rims up to about 1970 will work. Maybe someone with "hands on" experience will be along shortly. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Can't say if the Colorado (chevy) 6 lug wheel is the same bolt pattern or not BUT I can tell you that late model(90 & up)6lug full size trick rims will only work w/the help of a 1/2inch spacer....Joe | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | The bolt pattern from my 2003 3/4 ton Savana is the same as my '53 half ton panel. I only used the wheels to roll the chassis around in the shop. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The backspace is too deep for use on the earlier trucks, especially on the 1/2 tons and even moreso on the Colorado. The bolt pattern on the '88 and up Silverado as well as the Colorado is the same as the earlier trucks. Up to '87 4x4 uses the same bolt pattern and backspace as the early trucks. 3/4 ton used a mix up to about '00, some have the deep backspace, some have the mid backspace (about 4"). The mid backspace wheels will work on the IFS trucks, might rub on a hard turn on the I beam trucks.
Bill Burmeister | | |
