11 members (Buckeye998, treegrower, carbking, dt235sd, Phak1, Rusty Rod, Gdads51, Bill Hanlon, 68ironhead, GMCJammer51, 1 invisible),
379
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | I am building a 1936 1\2T high cab. I say building because everything was apart when I bought it. This truck has wooden sills that mount on top of the frame. I have located the front section and I can connect the sill to that. How, what and where do I connect the rear bolts. Anyone know where I can get this information?
Thanks | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | If I understand you then you are wanting to connect the bolts that are behind the seat. On mine it is all wood also. There are two big springs with plates and a floating bolt in the center that hold down the wood to the frame or wood block underneath to the frame(metal frame of course) Anyway this spring kind of holds down and also keeps the back of the truck sort of floating and keeps it from bouncing up as well. Maybe you can see these in your parts. Should be a whole in the frame to accept all this. Mine were very rusty and needed some furbishing to work. I haven't seen any for sale anywhere. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | was this the cb205 set. I knew there were wood blocks under the front, didn't realize there were also wood blocks in the back mounts also. | | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Yes CB205. Only thing with the 36 is the rear cab mounts were too short. | | | | | Joined: Feb 2008 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 130 | I didn't realize that was the springs and such that would work for the '34 as well. Thanks for the info! I can replace those rusty ones i have. | | |
