2 members (Hanks custodian, 1 invisible),
124
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 59 | My truck (a 64 C50) has a Lever Lock mounted through the dash. I already know the pitfalls of relying on these units as I have had experience with them failing on forklifts. I'm just wondering if it would have been factory equipment. The truck has the drum style, handle operated brake on the driveline, so I am wondering why this would have been installed on the truck.
There's no PTO or anything so rule that out.
Brian | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Seriously doubt it was factory equipment but it could have been installed soon after.
Got a picture?
Grigg | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Grigg is right. Mico BrakeLoks were aftermarket equipment and often installed by the selling dealer or an equipment company such as I had. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Wreckers used them and we used them om bobtails to hold them while pumping off gasoline. We always used chock blocks too. They were usually installed at the time a PTO was installed. Your truck must have done something during its life that required something to hold the truck while the engine was running. They were never meant to be a so called parking brake. | | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | You didn't say what was on the rear of your C50 but my guess is someone installed it so the truck would sit still. We had Micro Locs on all our wreckers and in the 9 years I drove them never once had a problem with them. We didn't use them as a parking brake, just used them when we were working the truck.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
