| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 56 | I've seen both discussed, but not compared. I'm ready to replace the points in my 65 C-10 230-L6, but not sure which way to go. Any advice whould be appreciated.
Thanks | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Pertronics in my '58 no complaints just keeps on humming. | | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | I'd say from a reliability standpoint it's a toss up. Stock HEI or Pertronics are both completely dependable.
About 20 years ago I built my 350 with a Mallory Unilite which was horribly unreliable. That convinced me I didn't want anything fancy, just something that worked - so I switched to a stock GM HEI and have never had a bit of trouble. And parts are available everywhere which is a plus.
On my 68 Ford 360 a Pertronics kit was the cheapest option, so I put one in and it has performed flawlessly for about 5 years now. If I were to do a V8 now, I'd probably lean toward the Pertronics, since it will fit in a small cap distributor, look more vintage, and provide better clearance than a large cap HEI. With an inline six, I'd go with whichever is less expensive since they both perform equally well. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I use the HEI when there are no clearance problems. I use the petronics when it is close to the firewall like 55-59. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 45 | both will work very well but you can have the pertronix installed and running in 15 minutes......... very simple to hook up and keeps the underhood area lookking stock if that's an issue for you. The biggest issue I've dealt with is when guys leave the key in the "ON" position with the engine off. This will burn out the pertronix. | | | | | Joined: Sep 2007 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 56 | Thanks for the info. Reliability is the issue, so I think I'll go with the HEI. I've got plenty of space under the hood with a 230. | | |
