2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | Hi Guys, I ordered the rectangular rubber stops and the little round rubber stops from Jim Carter's, but my truck came with none on it, so I need to see how they are supposed to go?
I "installed" the rectangular ones already but I put no adhesive on them (is it just me or do they remind you of the adjustment hole plugs in drum backing plate?).
The 3/4" dia. flat rubber discs are a different question. I see a hole, top and bottom that LOOKS like it might be the place for these. One of these holes has an 8-32 x 3/4" long, counter sink, domed and slotted screw in it. Is this where these discs go?
I was only able to find flat topped, counter sunk, Phillips zinc screws. I had intended on finding identical sloted screws in stainless, but couldn't.
Can you please post pictures of how/where these are to be installed? | | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | NOBODY has a pictures of their door bumpers? Windlacing? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Dan, I believe that new rubber piece goes into another metal part, I'll have to look at mine and get back to you. These trucks had no rubber around the doors, just the windlace. The windlace is held in place by a metal strip that goe around the door on the inside. Check out my 46 pics, may be a photo good enough showing the windlace. And I'll get you a photo of the other pieces you need, you may need to remind me. Best of luck Jim | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | Heres some photos: Click. Sorry I can't get my website to work with internet explorer. | | | | | Joined: Nov 2008 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 101 | Thank you guys, I searched through all the available links and kingsisomer's pix show the little rubber circle things I am asking about. It looks like I was right as to where they go. The other rectangular rubber things are installed like mine too. I only wonder if I'm supposed to put some kind of adhesive on them because they don't seem all that secure to me.
Any additional, clearer pictures would be really appreciated. | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | Not sure I understand what you don't understand. What aspect of the stops do you want the picture to depict more clearly? I'll try to get better pics. | | |
