| | | Forums66 Topics128,056 Posts1,055,792 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 22 Apprentice | | Apprentice Joined: Jan 2009 Posts: 22 | Ok, in the process of converting my '63 k10 to power steering. I've got the steering box mounted with an adapter plate that I made. The problem I having is that the drag links that I have (one off the '63 and one off a '78 4x4) are too long even if I turn them all the way in. Plus it looks like when I turn, the drag link is going to take a high angle. The high angle doesn't look that bad though, but it is a little higher than with the manual steering gear. I am still using the 44-5f front axel. Thought about getting one for a lifted truck to see if that would work. Also thought about making one out of some d.o.m. tubing and some heim joints. Has anyone got any ideas?
"63 K10 chevy,406 mpfi small block, 350 trans, 33" tires.
| | | | | | quirt111 Unregistered | | quirt111 Unregistered | My 57 truck has a 84 Blazer drive line and axles. My drage link it paralel to the ground because the "pitman arm" I guess its called that runs from the spline shaft of the steering box to the link has been welded to make it longer. Make sure you know exactly what rod and heat range to use because you want that joint never to fail. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'd be worried about bump steer if your drag link isn't coming out in the right place. How did you choose the location for the steering box? If you duplicated the arrangement from a later truck you should be able to adapt the steering arm, drag link and pitman from that truck.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2009 Posts: 22 Apprentice | | Apprentice Joined: Jan 2009 Posts: 22 | Problem is the truck that I took the gear off of doesn't sit as high as my '63. The '78 has the GM 10 bolt diff. the '63 has the Dana 44-5f diff on it. The steering arms on the diffs. are totally different. I don't want to change out my diff. just to have power steering though. I found a drag link for raised trucks that might work. Instead of being straight, it is shaped like an "s" and I can get on with a 2" to a 6" suspention lift.
| | | | | Joined: Jan 2009 Posts: 22 Apprentice | | Apprentice Joined: Jan 2009 Posts: 22 | Well my truck is still in my shop. Can't figure out the drag link yet. It's going to have to be a short drag link, about 3in. shorter. I've tried turning the ends in all the way, but it is still to long. I'm stuck. As far as the angle issue, I can just use a dropped pitman arm.
