Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (NJC, 1955 1 Series, Wayne67vert, 1 invisible), 141 guests, and 3 robots.
Topics128,281
Posts1,058,471
Members48,490
#594835 11/23/2009 5:11 AM
rkf
Offline
Apprentice
Apprentice
Ok, in the process of converting my '63 k10 to power steering. I've got the steering box mounted with an adapter plate that I made. The problem I having is that the drag links that I have (one off the '63 and one off a '78 4x4) are too long even if I turn them all the way in. Plus it looks like when I turn, the drag link is going to take a high angle. The high angle doesn't look that bad though, but it is a little higher than with the manual steering gear. I am still using the 44-5f front axel. Thought about getting one for a lifted truck to see if that would work. Also thought about making one out of some d.o.m. tubing and some heim joints. Has anyone got any ideas?
"63 K10 chevy,406 mpfi small block, 350 trans, 33" tires.
rkf #596141 11/27/2009 4:40 PM
Q
quirt111
Unregistered
quirt111
Unregistered
Q
My 57 truck has a 84 Blazer drive line and axles. My drage link it paralel to the ground because the "pitman arm" I guess its called that runs from the spline shaft of the steering box to the link has been welded to make it longer. Make sure you know exactly what rod and heat range to use because you want that joint never to fail.
#599507 12/09/2009 1:01 AM
I'd be worried about bump steer if your drag link isn't coming out in the right place. How did you choose the location for the steering box? If you duplicated the arrangement from a later truck you should be able to adapt the steering arm, drag link and pitman from that truck.
OldSub #599812 12/09/2009 10:47 PM
rkf
Offline
Apprentice
Apprentice
Problem is the truck that I took the gear off of doesn't sit as high as my '63. The '78 has the GM 10 bolt diff. the '63 has the Dana 44-5f diff on it. The steering arms on the diffs. are totally different. I don't want to change out my diff. just to have power steering though. I found a drag link for raised trucks that might work. Instead of being straight, it is shaped like an "s" and I can get on with a 2" to a 6" suspention lift.
rkf #606646 01/03/2010 5:20 AM
rkf
Offline
Apprentice
Apprentice
Well my truck is still in my shop. Can't figure out the drag link yet. It's going to have to be a short drag link, about 3in. shorter. I've tried turning the ends in all the way, but it is still to long. I'm stuck. As far as the angle issue, I can just use a dropped pitman arm.
