1 members (baldeagle), 61 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#595250 11/24/2009 6:56 PM
Z
Z Offline
Most of our clips for our spring leaves are broken or about to be broken. I have looked, and i am unable to find replacements on the web. can i make my own? or does somebody know a site? thanks
2000 Nissan Frontier, 3.3L (sold)
2006 Chevy Cobalt SS, 2.4L
1952 Chevy 1/2 pickup, 235 c.i. I6
when life speeds up, downshift
Yes, you could make your own if you have a steel supplier nearby for the right gauge or try to locate a spring shop near you.
Drew
DrewP #595548 11/25/2009 3:50 PM
Its easy to make new ones once the leaf spring pack is apart. Measure the ones left and cut the new flat stock the same length. Use a heavy rivet to hold the new strap on ( I found some at my local ACE hardware store ), then assemble the pack and bend the ends over. I use a piece of sheet metal, (.062" thick) as a spacer so the straps don't lay right on the top spring. I think the last ones I made were from 3/4" x 1/8" flat steel stock from the local hardware store.
I did have to use some heat to get nice sharp bends, but all in all its real easy to do.
Joe
DrewP #595551 11/25/2009 3:52 PM
I would take the entire spring pack to a local spring shop. THey can rebuild them & ensure they are correctly held together. Believe it or not - they shouldn't cost much.
They should clean them up really well too.
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
