2 members (NJC, baldeagle),
57
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 69 New Guy | | New Guy Joined: Sep 2009 Posts: 69 | Most of our clips for our spring leaves are broken or about to be broken. I have looked, and i am unable to find replacements on the web. can i make my own? or does somebody know a site? thanks
2000 Nissan Frontier, 3.3L (sold) 2006 Chevy Cobalt SS, 2.4L 1952 Chevy 1/2 pickup, 235 c.i. I6 when life speeds up, downshift
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Yes, you could make your own if you have a steel supplier nearby for the right gauge or try to locate a spring shop near you.
Drew
| | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | Its easy to make new ones once the leaf spring pack is apart. Measure the ones left and cut the new flat stock the same length. Use a heavy rivet to hold the new strap on ( I found some at my local ACE hardware store ), then assemble the pack and bend the ends over. I use a piece of sheet metal, (.062" thick) as a spacer so the straps don't lay right on the top spring. I think the last ones I made were from 3/4" x 1/8" flat steel stock from the local hardware store. I did have to use some heat to get nice sharp bends, but all in all its real easy to do.
Joe | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I would take the entire spring pack to a local spring shop. THey can rebuild them & ensure they are correctly held together. Believe it or not - they shouldn't cost much.
They should clean them up really well too. | | |
