2 members (Bill Hanlon, Steelonsteel), 131 guests, and 2 robots.
Topics128,062
Posts1,055,854
Members48,428
#59547 04/23/2006 6:03 PM
I been workin on my 64 chevy truck and my dad and i dropped a 350 automatic. I dont know much about mechanics for i am learning lil at a time. Anyways there is this ticking noise or somthing when i start it up and it stays at the same noise the whole time. Could it be the lifters? I am lost at this point. I hate to have to drive my truck around sounding like that and i dont want it to effect my engine and all. ANy clue. Sorry for the lil info i could share. Blah!!!
Stovebolt-It is painted
#59548 04/23/2006 6:15 PM
Lifter noise will increase/decrease with engine speed.It is very hard to tell what it is without hearing it for myself.Here are some things to check.
1)oil level full but not overfull?
2)using a pipe or hose can you pinpoint the
area it is comming from ?
3)try to load the engine(in gear)to see if
noise gets louder
4)let us know what you find out
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#59549 04/24/2006 3:08 AM
Using a solid rod or long screwdriver 18" or longer touch the end of the solid rod to the engine part that is making noise.With your ear next to rod you should hear the noise very clear I use this tequnic for manny engine noises including generator bearings.CAUTION keep away from moving parts.
#59550 04/24/2006 3:27 AM
If you rev her up and the ticking doesnt increase, it might be an exhaust leak. I had a truck that did that and I thought it was the lifters but it was a hole in the pipe next to the firewall.
Depending on where it is and how big/small a hole makes a big difference as to the sound it makes.
Let us know what u find. Good luck
My 1953 Chevrolet
1947.1 Gallery
#59551 04/24/2006 10:16 PM
Riding in the Passing Lane
Good points. Also check around the fuel pump. It can make a ticking noise.
1972 Chevy c10 Cheyenne Super
