| | | Forums66 Topics128,078 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Going to install the rebuild kit in the stock master cylinder this weekend on the 51 Chevy 1/2 ton. Anyone have any problems or tips from your experiences you wish to share? Thanks as always for your advise.
Hank | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i have rebuilt several from the 60's and one on my 53 hudson. if you can hone out within correct pidton to wall clearence you should be able to use it. i have even used a little out with no leaks or ill effects. some people like to bench bleed before installing to make bleeding easier. good luck. | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | This was a very satisfying project for me. I have not tricks to offer- the rebuild was rather straight-forward as long as you are methodic. Get you an appropriately sized hone before you put it back together. Like hoggyrubber said: bench bleed it before installing. You be glad you did later.
Do a search on Stovebolt. It has been discussed quite a few times. You'll learn lots by reading others' past experiences.
Bill | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | keep it clean - these rusty old cyls can hide a lot of crap inside. Just clean everything well & all will be fine. It is really easy to do. | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Thanks for the reply/info. fellas, I appreciate it. I did use search before I posted this, just wanted to know if anyone had anything else to add.
Hank | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i do remember 1 thing i like to do. the shop manual has you cleaning parts with alcohol. i have a big jug of it but i also got some of those small no lint alcohol wips that work well on the pistons and such. that's the closest thing i have to a trick. good luck. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Got no tricks HankDogg but give me a call if you need any help or need a hone. I think I have new stones on mine.... | | | | | Joined: Sep 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 461 | Thanks for the tip on the wipes...hadn't thought of that one. I appreciate the hone offer Alvin, Happy Thanksgiving guys!
Hank | | |
