7 members (Peggy M, Stewart2, Steelonsteel, moparguy, Millenimech, 2 invisible), 136 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#595416 11/25/2009 2:58 AM
Going to install the rebuild kit in the stock master cylinder this weekend on the 51 Chevy 1/2 ton. Anyone have any problems or tips from your experiences you wish to share? Thanks as always for your advise.
Hank
1951 restoration on website
http://www.hanklong.com
i have rebuilt several from the 60's and one on my 53 hudson. if you can hone out within correct pidton to wall clearence you should be able to use it. i have even used a little out with no leaks or ill effects. some people like to bench bleed before installing to make bleeding easier. good luck.
This was a very satisfying project for me. I have not tricks to offer- the rebuild was rather straight-forward as long as you are methodic. Get you an appropriately sized hone before you put it back together. Like hoggyrubber said: bench bleed it before installing. You be glad you did later.
Do a search on Stovebolt. It has been discussed quite a few times. You'll learn lots by reading others' past experiences.
keep it clean - these rusty old cyls can hide a lot of crap inside. Just clean everything well & all will be fine. It is really easy to do.
1958 Chevy Apache 3200
bone stock 235
53k miles
3 on the tree
Thanks for the reply/info. fellas, I appreciate it. I did use search before I posted this, just wanted to know if anyone had anything else to add.
Hank
i do remember 1 thing i like to do. the shop manual has you cleaning parts with alcohol. i have a big jug of it but i also got some of those small no lint alcohol wips that work well on the pistons and such. that's the closest thing i have to a trick. good luck.
Got no tricks HankDogg but give me a call if you need any help or need a hone. I think I have new stones on mine....
Thanks for the tip on the wipes...hadn't thought of that one. I appreciate the hone offer Alvin, Happy Thanksgiving guys!
Hank
