3 members (Phak1, Joe H, Bill Hanlon), 116 guests, and 1 robot.
Topics128,115
Posts1,056,625
Members48,450
I was wondering if anyone might have a scale drawing or dimensions for a side mount spare tire carrier.
I have been looking to purchase one for a fair price but turned up empty hand.
It doesn't seem to hard to fabricate with the right measurements and angles for the rod placement.
Thx
I can get you some measurements off the one sitting on the back of this frame if you want. It bolts to the bedsides and came off my 53 Chevy bed. It is not for sale, I will be using it on the T'Mater
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
1953 Chevrolet 3600
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
I would not mind a clear set of drawings for your spare tire carrier also.
It's all documented in the pdf link in the tech tip from above.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
The pdf link is great. It has good info....Is there anything with something closer to the '53 model?
I think he was referring to my offer 54tow
I have taken seven pictures with a tape measure next to it. one of the mounting points is bent a hair and I can't figure out which one. The basic dimensions are 11 1/4" between the heavier mounting holes and 12 1/4" hole to hole on the other three dimensions. the unit when mounted will be 9 1/2" off the face of the truck side. The triangular piece is 8" on all long sides and the short (cut-off) end is 2". The studs will have to be located to fit your wheels. Mine is for 8 lug wheels. The pictures are located in my photobucket folder
1953 Chevrolet 3600
Thank you...This is great help, I see if I I can fab one this weekend. Thx
I believe the 3/4 ton AD, with the long bed, does not need to have a formed fender to fit the tire.
~Jim
