4 members (GMCJammer51, Bill Hanlon, Otto Skorzeny, Phak1), 109 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#594515 11/22/2009 6:28 AM
Apprentice
Apprentice
On a 51 GMC 4 Speed, what is the correct seal for the steering colume? I see a round seal is available but the hole where the colume goes through is not round but oblong in shape. If I just install the round seal there is a big gap still in the fire wall. If anyone one has any answers I would greatly appreciate them. Thanks,
It is oval to allow a 3 speed shift rod....
GMC: Get More Cash...
1958 GMC
My Webshots photos
I've got a 53 GMC setting in My drivway and it's a 3/4 ton with a 4 speed it has the oval floor seal in it the one used for a 3 speed shift rod I do not know alot about GMC's but it looks like it came that way nothing else on the truck has been changed .
Pete
On a 4 speed, it should look something like this. The 3 speed has another hole for the shift rod at the top.
Bruce
My Trucks
Stuff I Collect
That is the only flange that is presently available from the vendors Bruce. But, the original cover was a teardrop shaped one, just like the one for the three speed except that it didn't have the upper hole for the shift lever. I had an original flange on mine when I brought her home; think I still have it around here somewhere. So once again, the after market reproduction parts are actually incorrect, just someone’s interpretation of what they thought it might have been.
The teardrop shaped hole in the toe board is the same for all the trucks 3sp or 4sp.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
....Mmmm, I'll have to dig out my repo Denny but darn if I don't believe its actually teardrop shaped? I've had it for a couple years.... I had started buying up parts as I tore the panel apart. Now I'll have to go dig it out to check and see.
IF it is the teardrop shape I don't need it as I am not going to run the shift lever.
