1 members (Hotrod Lincoln), 327 guests, and 3 robots.
Topics128,169
Posts1,057,102
Members48,463
2 Offline
I have a 55 2nd series that I want to convert to disc brakes. I need 5 on 5 big chevy bolt patern to match my rear axle. All the kits I find use the small chevy bolt patern. Does anyone know of a kit that uses the big 5 on 5 patern ?
you might have to go to the 6 lug kit and have the hubs and discs redrilled for the 5 on 5 pattern. This would give you 12 inch brakes. I do not know if it is possible to redrill the camaro rotor to a 5 on 5 pattern.
Another option might be to cross reference the bearings to see if the '89-'96 Caprice/Impala rotor would work, as they are 5x5.
Bill Burmeister
I looked at the Camaro rotor and I didn't see an easy way to redrill it for 5" bolt pattern. I wish I had known about the 89-96 Caprice rotor.
I am using a Lincoln rear end that has disc brakes and has a 5X5 bolt pattern. In my case it would be easier to redrill the rear axle and rotors for 5X4.75 to match the Camaro rotors.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
Only the station wagon and police cars (myabe cabs) have the big 5X5 pattern, the reagular cars have the smaller, 4.75X5, I think.
'57 Chevy Suburban; '70 Chevy Impala.
There are adapters to go from 5 x 4.75 to 5 x 5
2 Offline
I have a set of 93 caprice rotors they have the 5 on 5 bolt patern but they are the
large rotors and will not work with the camero sized kits. My rear axle is from the 93 caprice. I don't want to use adapters . I have found some circle track rotors that are the camero sized rotors that are 5 on 5. Think I'll buy the brackets and get those rotors..
I've checked the spec book, '90 (I was 1 year off) to '96 "Bubble" body Caprice and Impala are 5x5, regardless.
Bill Burmeister
will the impala bearings work on the 57 spindle, or would bushingshto be made?
Stepside57
2 Offline
The bearings are larger and the rotors are 12 inches. I did find a machine shop that would redrill the mid size rotors to a 5x5 for $30.00 each. Turns out the circle track rotors that are 5x5 have 5/8 wheel studs that won't work with stock wheels. Who has the best price on a disc brake kit ? Think I going to get a kit and have the rotors redrilled to 5x5.
Thank you. I think I will do the same, the 12" rotor kit from CPP that work with the 57 hubs.
Stepside57
I have a set of rotors taken from a 1969 Impala that are the 5 on 5 pattern. They fit on the same spindles as the smaller Camaro and Nova rotors they also have much larger calipers.
