1 members (Alex52),
136
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | I have a 55 2nd series that I want to convert to disc brakes. I need 5 on 5 big chevy bolt patern to match my rear axle. All the kits I find use the small chevy bolt patern. Does anyone know of a kit that uses the big 5 on 5 patern ? | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | you might have to go to the 6 lug kit and have the hubs and discs redrilled for the 5 on 5 pattern. This would give you 12 inch brakes. I do not know if it is possible to redrill the camaro rotor to a 5 on 5 pattern. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Another option might be to cross reference the bearings to see if the '89-'96 Caprice/Impala rotor would work, as they are 5x5.
Bill Burmeister | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I looked at the Camaro rotor and I didn't see an easy way to redrill it for 5" bolt pattern. I wish I had known about the 89-96 Caprice rotor.
I am using a Lincoln rear end that has disc brakes and has a 5X5 bolt pattern. In my case it would be easier to redrill the rear axle and rotors for 5X4.75 to match the Camaro rotors. | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Another option might be to cross reference the bearings to see if the '89-'96 Caprice/Impala rotor would work, as they are 5x5. Only the station wagon and police cars (myabe cabs) have the big 5X5 pattern, the reagular cars have the smaller, 4.75X5, I think.
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | There are adapters to go from 5 x 4.75 to 5 x 5
| | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | I have a set of 93 caprice rotors they have the 5 on 5 bolt patern but they are the large rotors and will not work with the camero sized kits. My rear axle is from the 93 caprice. I don't want to use adapters . I have found some circle track rotors that are the camero sized rotors that are 5 on 5. Think I'll buy the brackets and get those rotors.. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Another option might be to cross reference the bearings to see if the '89-'96 Caprice/Impala rotor would work, as they are 5x5. Only the station wagon and police cars (myabe cabs) have the big 5X5 pattern, the reagular cars have the smaller, 4.75X5, I think. I've checked the spec book, '90 (I was 1 year off) to '96 "Bubble" body Caprice and Impala are 5x5, regardless.
Bill Burmeister | | | | | Joined: Oct 2007 Posts: 3 New Guy | | New Guy Joined: Oct 2007 Posts: 3 | will the impala bearings work on the 57 spindle, or would bushingshto be made?
Stepside57
| | | | | Joined: Mar 2008 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 60 | The bearings are larger and the rotors are 12 inches. I did find a machine shop that would redrill the mid size rotors to a 5x5 for $30.00 each. Turns out the circle track rotors that are 5x5 have 5/8 wheel studs that won't work with stock wheels. Who has the best price on a disc brake kit ? Think I going to get a kit and have the rotors redrilled to 5x5. | | | | | Joined: Oct 2007 Posts: 3 New Guy | | New Guy Joined: Oct 2007 Posts: 3 | Thank you. I think I will do the same, the 12" rotor kit from CPP that work with the 57 hubs.
Stepside57
| | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have a set of rotors taken from a 1969 Impala that are the 5 on 5 pattern. They fit on the same spindles as the smaller Camaro and Nova rotors they also have much larger calipers. | | |
