| | | Forums66 Topics128,049 Posts1,055,698 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Well I have tried new gaskets, the foam & rubber...current is foam. But after cleaning,prepping,painting an just bought everything I can think of to seal this unit when closed alludes me! The Cowl vent opens and closes smooth when closed it is not askew in anyway ..I mean it seems to be setting with the same gap all around and sets flush to the cowl. BUT ...NOW THERE'S ALWAYS A BUT isnt there. When in a good rain or just washin the Truck in the yard water just POURS in to the inside. ANY TIPS to fix???? P.S. new and open drain line installed.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Tim, have you actually witnessed where the water enters,is it simply overwhelming the seal or is it coming through a seam? As you will be aware,the cowl section is not a one piece pressing.Paint alone will not seal it. I imagine they were probably seam sealed all those years ago,but the sealer dried,cracked and fell out over time. Sounds like you need to get flexable and get under the dash with a torch while Mrs Radial,or some other helper sprays the truck with a hose.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My 38 has an adjustment on the open/close lever assembly. If your's does as well, maybe snug it up a notch?
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | If you can't get the vent down to the seal get the seal up to the vent.
Does the vent sit flush with the cowl? If so the seal is too short and you should start thinking of ways of raising it or filling the gap. If the vent is above the surface of the cowl look for an adjustment.
Good luck. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Have we ruled out the drain hose? Its there for a purpose. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | "P.S. new and open drain line installed."
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "When in a good rain or just washin the Truck in the yard water just POURS in to the inside."
Tim,
Is there a chance that the leak is at the windshield gasket? Have you tried having someone pour water directly on the closed vent while you observed under the dash?
Tim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..... my GUESS is its not sealing around the gasket. Let us know what you find Tim....after you squiggle around under the dash while Seth shoots the water at it. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Well this mornin before school I took Alvin's advise and had Sethy hit the cowl vent vigorously with a squirt bottle while I watched from inside it is defiantely coming in around cowl seal,I have the handle adjusted so that the cover is pretty tight when closed, I tried putting some white grease on the foam seal and closing it up ...there are spots were the vent cap doesnt even touch the seal. So I now going to make a template and make a 3/16" shim and get another seal and shim it up, that should fix this prob. Thanks for teh Idears Folks!!! Tim | | |
