| | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | I've heard that rust converter from Eastwood is a good product. I checked out their website, but the information was limited. Have any of you guys used it? I'm planning on using it on a car trailer. Would a good pressure washing be good enough prep work? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I used there Rust converter topped with there rust encapsualtor on my 52's windshield frame perimeter (were the gasket sets) before painting with great success. I also tried it on my trailor hitch on my 97 Dodge,I basically removed all the rust I could with a wire brush and then applied the converter topped with encapsulator then topcoated it with Rustoleum brush on ...(2 coats). Rust started to creep out again at the seems and some weld joints after bought 3 months of PA winter and salt and at this time it needs to be redone as I feel the converter could not get into the seems and joints deep enough to kill the rust that was already there. If I was to do it again I would remove my hitch and have it sandblasted then paint. I would suggest getting rid of as much of the rust as you can before applcation,Just my review of the product. Tim | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | The sad fact of the matter is that nothing is going to neutralize rust between two pieces of metal such as lap joints. The product must come in contact with the rust itself so unless you submerge something like a cab in the product long enough for the product to seep into every crevice the rust will continue to grow.
Do the best you can and keep moisture away from the rust.
I use Eastwood Rust Converter and Encapsulator and find it works very well... as long as it comes in contact with the rust. | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Make sure there is still some rust on the metal, don't go down to bare shiny metal! Had a bad experience in the past. | | |
