1 members (TooMany2count),
81
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | Hi to all I recently purchased a 1968 C60 grain truck that has sat for about the last three years. When I took the cover off the brake reservoir it was completely DRY. I filled it with fluid and hit the pedal with the cover off to see if there was any movement in the fluid like disappearing down the brake line. So nothing. I know nothig about this type of system and see no leaks at the wheel cylinders. Where do I start? Worried I have bought a money pit!
Thanks | | | | | Joined: Aug 2009 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 50 | any vehicle that has sat for 3 years will cost money | | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | I did a complete tune-up and the truck runs like a clock. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | there is a diaphram in the hydravac that may need to be replaced ron | | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | go to the gallery and check out robert burgoyne's '64 c60. he's got a pretty good web page with pics and a link to a company for parts for hydovac. haven't been there, but I'm in the process of buying a '66 c60 dump truck and I'll be there soon enough. good luck. most brake systems are pretty simple. push the fluid to make the shoes move. take it apart make sure it has good sealing surfaces, re-seal it and it will probably work just fine.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
| | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | Thanks I just received an email from him this morning with some tips. | | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | Is the diaphram a matter of o-rings or more like a balloon (water tank bladder)? | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I I can remember correctly it was shaped like a pie plate, like what used to be used in maxi brakes( for big trucks, perhaps 6-7"s in dia. ron | | |
