4 members (Shade Baby, 1955 1 Series, 55shaker, Wally / Montana), 119 guests, and 4 robots.
Topics128,139
Posts1,056,448
Members48,441
#591346 11/10/2009 7:47 PM
Hi to all
I recently purchased a 1968 C60 grain truck that has sat for about the last three years. When I took the cover off the brake reservoir it was completely DRY. I filled it with fluid and hit the pedal with the cover off to see if there was any movement in the fluid like disappearing down the brake line. So nothing. I know nothig about this type of system and see no leaks at the wheel cylinders. Where do I start? Worried I have bought a money pit!
any vehicle that has sat for 3 years will cost money
I did a complete tune-up and the truck runs like a clock.
there is a diaphram in the hydravac that may need to be replaced
ron
go to the gallery and check out robert burgoyne's '64 c60. he's got a pretty good web page with pics and a link to a company for parts for hydovac. haven't been there, but I'm in the process of buying a '66 c60 dump truck and I'll be there soon enough. good luck. most brake systems are pretty simple. push the fluid to make the shoes move. take it apart make sure it has good sealing surfaces, re-seal it and it will probably work just fine.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1964 c-60 dump truck
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
Thanks I just received an email from him this morning with some tips.
Is the diaphram a matter of o-rings or more like a balloon (water tank bladder)?
I I can remember correctly it was shaped like a pie plate, like what used to be used in maxi brakes( for big trucks, perhaps 6-7"s in dia.
ron
