| | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | I just un packed my bed sides and front bed panel and it looks like they are painted black. Do I need to strip these to bare metal or is it ok to just scuff them, prime and paint? I got the parts from the old Chevy Duty. It's been awhile since I have had time to work on the old truck. Thanks Eric. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's EDP, Electro Deposited Primer. It does not need to be removed, scuff, prime, and finish as usual. The OEMs use the same primer to prevent rust on new vehicles.
Bill Burmeister | | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | Thanks Longbox55. I thought it would be ok, just thought I would ask to make sure. You are from Danville, Ill. I used to live in Taylorville,Ill. It's about 30 miles south of Springfield. It's a small world. Thanks again for the info Eric. | | |
