Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
0 members (), 122 guests, and 3 robots.
Topics128,290
Posts1,058,557
Members48,491
#589891 11/05/2009 4:59 AM
I have a 70' 3/4 ton GMC with 8 bolt split rims 16". Will the newer 8 bolt rims from a 2000 up 3/4 GM brand truck work. I think those rims would look good on my truck. Plus then I could get rid os the split rims. If anyone is intersted in them I could ship them if I get new rims.
1949 Chevy 4400 Grainbed
Photobucket pictures
The taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back!
Behind every successful rancher is a wife who works in town.
I believe the bolt pattern is the same, but you may want to try and bolt them up to see if the center is big enough.
' Offline
Bolt pattern is the same, and the center hub should be as well. The biggest concern (from what I have seen) with putting modern rims on an older truck is the backspacing and brake clearance.
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Those rims will rub the tie-rod ends w/out at least a 1/2inch or more spacer..
