1 members (Jimmie D),
110
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Can anybody tell me how many amps the Heater motor in this picture draws. I think it is from a 1930's vehicle and is definitely 6V. I have one voltage reducer 12v-6v connected so far which gets hotter than a two dollar pistol. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The heater will draw around 8 amps and across 6 volts thast is 48 watts. The resistors that they sell get very hot and they are contained in a metal shell. It should be mounted on some sheet metal to disapate the heat. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Thanks truckernix, that's what I needed to hear. Would an aluminum mounting plate help with heat dissipation or would steel be better? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | As long as the heat can go somewhere. it really doesn't matter. If I were doing it, I would probably attach it somewhere above the kick panel where there is a bit of an inner panel. I think the antenna brace attaches in the area that I am thinking of. | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | how many ohms would that resistor need to be ? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It should be a little less than 1 ohm. It would be 6v/8A or about .75 ohms. Some fan motors may draw a little less. | | |
