4 members (Jon G, Joe H, J Lucas, Phak1), 74 guests, and 3 robots.
Topics128,050
Posts1,055,646
#588367 10/31/2009 5:11 PM
Can anybody tell me how many amps the Heater motor in this picture draws. I think it is from a 1930's vehicle and is definitely 6V. I have one voltage reducer 12v-6v connected so far which gets hotter than a two dollar pistol.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
The heater will draw around 8 amps and across 6 volts thast is 48 watts. The resistors that they sell get very hot and they are contained in a metal shell. It should be mounted on some sheet metal to disapate the heat.
1951 1 Ton Completed
Thanks truckernix, that's what I needed to hear. Would an aluminum mounting plate help with heat dissipation or would steel be better?
1953 Chevrolet 3600
As long as the heat can go somewhere. it really doesn't matter. If I were doing it, I would probably attach it somewhere above the kick panel where there is a bit of an inner panel. I think the antenna brace attaches in the area that I am thinking of.
how many ohms would that resistor need to be
It should be a little less than 1 ohm. It would be 6v/8A or about .75 ohms. Some fan motors may draw a little less.
