2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#588825 11/01/2009 10:39 PM
does any body have any idea were you can get the contact that comes out of the case for the floor start switch ,on a 1940 1/2 ton .its the copper contact that clamps to the starter case from the fields to make the contact from the stomp switch .
old dog #589010 11/02/2009 3:35 PM
I think your starter may have common parts for quite a few years following your year.
1951 1 Ton Completed
truckernix #589177 11/03/2009 1:57 AM
Ken Warner at, http://www.classicgenerator.com/
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
That terminal comes in a kit with new contact, insulators, case insulators etc. If your lucky you can replace that without removing the coils, I say this because if the wrapping on the coils is old then you risk ripping the insulation when you bend the coils leads back after you unsolder them. You just have to be careful when doing it. You also will need a good soldering tool that will heat up fast and hot. Denny supplied you with my email address above, thanks Denny, shot me an email and I will give you a price on the kit or any other parts you may need for that starter.
Ken
Kennethw #589352 11/03/2009 4:33 PM
well i was lucky and found the part's local ,with a lot of looking .the terminal that i was able to find was about 1/8 longer and had no threaded hole in it ,but a cnc hack saw and a little drill time on the mill and a 8-32 tap and we made it .but thanks for the help guy's !
