1 members (JW51),
137
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | does any body have any idea were you can get the contact that comes out of the case for the floor start switch ,on a 1940 1/2 ton .its the copper contact that clamps to the starter case from the fields to make the contact from the stomp switch . | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think your starter may have common parts for quite a few years following your year. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ken Warner at, http://www.classicgenerator.com/ Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | That terminal comes in a kit with new contact, insulators, case insulators etc. If your lucky you can replace that without removing the coils, I say this because if the wrapping on the coils is old then you risk ripping the insulation when you bend the coils leads back after you unsolder them. You just have to be careful when doing it. You also will need a good soldering tool that will heat up fast and hot. Denny supplied you with my email address above, thanks Denny, shot me an email and I will give you a price on the kit or any other parts you may need for that starter. Ken | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | well i was lucky and found the part's local ,with a lot of looking .the terminal that i was able to find was about 1/8 longer and had no threaded hole in it ,but a cnc hack saw and a little drill time on the mill and a 8-32 tap and we made it .but thanks for the help guy's ! | | |
