1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 8 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 8 | This is my first trial of completely doing a truck myself. My panel truck was brought down to Arizona from Rugby, North Dakota by my friend's father. He intended to fix it up but it ended up sitting on his front driveway for years. I kept asking him if he wanted to sell it but he said he was going to fix it up someday. It never happened and he finally sold me the panel a year ago. The truck had the original 216 motor with 67,000 original miles on it. It still ran but not very well. I opted instead to install a freshly rebuilt 58-62 235 in place of the 216 using the shortened water pump. I converted the panel to 12 volt using a GM one wire alternator and an HEI distributor from 1985 chevy pickup with a 250 motor. I got other parts to get it running well like a freshly rebuilt radiator from the good people here on Stovebolt.com. Now for the main problem the truck had.... rust! The cab was pretty good but all of the fenders and running boards had holes as big as 4 inches in diameter. Needless to say, about 150 hours of welding and bodywork took place to patch all of the rusty areas. I painted the truck and tried to incorporate the original sign into the scheme. The school I work in was built in 1948. The remodeled last year and ripped out all of the original intercom boxes. I took them and mounted speakers in them and mounted them on the rear doors. It fits the look of the panel and I didn't have to cut any holes in my truck. Still not finished but I took it to it's first car show a few weekends ago and It turned a few heads so I was pretty proud![IMG] http://i83.photobucket.com/albums/j293/juddmorgan/10330_1154090296740_1362175569_3-3.jpg[/IMG]
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Judd....Wow! If that's your first, what are you going to do for an encore!  I like the way you've retained the original artwork too. Great job,you should be proud! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | | | |
