2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
#587926 10/30/2009 4:44 AM
Anyone found a good donor car power window setup that works on an A/D truck?
Dan B. #587945 10/30/2009 11:16 AM
nothing that is a simple drop in.
I used the motors and part of the regulators from a mid 70's caddilac on mine,cut the ends of the caddy regulator arms an welded the AD tips on.
they work pretty good.
PM me for more info..I didnnt ever take any pics while they were out of the doors sorry..i could pop off the door panels an get ya a few pics of how they work an fit..it is tight in there.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #588143 10/30/2009 11:40 PM
SW_Radial:
Thanks for offering but I wouldn't ask you to do that. I have thought of all the compact cars in salvage yards with slimline doors and power windows. Long as one had enough vertical travel seems like it would work.
Dan
Dan B. #588529 11/01/2009 2:19 AM
If you try it and it works, take mucho pics and do a report on how you got it done. I'll pay you $150,000.00 for the report.
~Jim
Dan B. #588622 11/01/2009 5:44 AM
Dan the problem with most modern cable and pulley type systems is they are designed to work with curved glass.i.e. the regulator follows an arc.
There are some lever type regulators that might work,but none that I know of at the moment.
It might take a junkyard 'tour' and some more research......
I'm not sure if you guys have the F*rd Transit over there,but i'm looking into that one myself.
They have a relatively compact,self contained lever type regulator.
More pix on Flickr.
What about the motors from a dodge pickup?
Chris
No Jock, no F%$d Transits over here. The E-350 passenger van is the closest I drove one when I lived over there and wonder why they haven't built them here. Great vehicles except for the steering wheel they put on the wrong side.
drive
~Jim
No Jock, no F%$d Transits over here. Great vehicles except for the steering wheel they put on the wrong side.
drive
And the smaller load capacity ones are wrong wheel drive! wink
More pix on Flickr.
Bolters:
I found some aftermarket PW kits for the A/D. A couple were based on the VW Golf cable and track system. I did a quick tour of a local Pick-N-Pull salvage yard and found only Golf's with manual windows. I'll go back when I can stay awhile and try some Asian imports.
Dan
Dan B. #589480 11/04/2009 1:15 AM
I haven't tried to do this yet, but go to a salvage yard that specializes in big rigs (Kenworth, Peterbuilt etc.) Their windows are flat glass and power units might be easier to work with.
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
Dan: I did this on my 52, works great. http://www.hotrodders.com/forum/jou...9&page=34&perpage=5&reverse=
It starts about half way down page 34 and is reversed The only problem I'm having is finding looms large enough for all the wiring. Jeff
New deal for old steel
