6 members (SNOYL, Jon G, Bill Hanlon, Robert Crandall, oldsteve, Otto Skorzeny), 79 guests, and 4 robots.
Topics128,180
Posts1,057,153
Members48,464
I bought an HO52 3rd member over the net that was supposed to have 4.10 gears. When I got it, it turned out to be 4.57. The seller has agreed to send me a set of 4.10 gears. I've never worked on a differential before so my question is how hard is it to change out the gears? Does it require any special tools? Is it covered in the '57 shop manual? I think I know where I can get a manual. Any advice will be greatly appreciated.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
3B Offline
Hy jfnar, you will need a dial indicator capable of measuring the backlash, it is the type that can be bolted/clamped into position on the differentials flange. The procedure is covered in the manual, you will also need a torque wrench to torque the crown gear to the carrier, good luck.
H Online: Content
They had better be brand new gears, or at least a tooth contact pattern would need to be run before the 4.10's are removed from whatever they're in now. Getting a used set of gears back in exactly the same running relationship in the original housing is difficult- - - -if you're putting them in a different housing it's dang near impossible to do without inducing a permanent gear howl. I've got a set of Dana type 60 3.78 gears I swapped from a Ford 3/4 ton housing into a GMC rear axle in my 59 Burb. I set it up as close to right as possible, and I still look over my shoulder for that fire truck siren that's following me around at times!
Where do you buy the dial indicator to measure the backlash?
Dennis
H Online: Content
Ebay, Harbor Freight Tools, Northern Tool & Supply, Snap-On, Enco Tools, Goodson, and K-Line are all good places to shop for a dial indicator. A good one with the adapters you'll need to set up a rear axle will cost about $100.00.
Thanks for the info. I hadn't thought about having a major noise problem with this. Considering I bought this 3rd member over the net I figured I was lucky that the guy was willing to send me the 4.10 gears when he could easily get away with shafting me. I'm out $265 now whether it works or not so I guess I'll just give it a shot and see what happens. Maybe I'll get lucky for a change. smile
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Are you getting a complete third member with the 4.10 gears? If so, you don't need to set anything.
1951 1 Ton Completed
If you've never done it before, I would have a driveline shop set it up for you,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Truckernix, I bought a 3rd member that was supposed to have 4.10 gears but when it arrived it had 4.57's. The guy is sending me some 4.10 gears to change out.
48bigtrucks, You're right, I think I'll take it to a pro. I don't mind tackling new things but I looked at the manual last night and it doesn't look real simple. Of course, the shop manual was written for people who alredy know what they're doing.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Inland Truck Parts and Service rebuilt my Eaton HO72 for about $250.00. Rearends are not cheap! At least I have peace of mind that it was done right.
Good Luck!
Dan M.
