| | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I bought an HO52 3rd member over the net that was supposed to have 4.10 gears. When I got it, it turned out to be 4.57. The seller has agreed to send me a set of 4.10 gears. I've never worked on a differential before so my question is how hard is it to change out the gears? Does it require any special tools? Is it covered in the '57 shop manual? I think I know where I can get a manual. Any advice will be greatly appreciated.
Jeff
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy jfnar, you will need a dial indicator capable of measuring the backlash, it is the type that can be bolted/clamped into position on the differentials flange. The procedure is covered in the manual, you will also need a torque wrench to torque the crown gear to the carrier, good luck. | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | They had better be brand new gears, or at least a tooth contact pattern would need to be run before the 4.10's are removed from whatever they're in now. Getting a used set of gears back in exactly the same running relationship in the original housing is difficult- - - -if you're putting them in a different housing it's dang near impossible to do without inducing a permanent gear howl. I've got a set of Dana type 60 3.78 gears I swapped from a Ford 3/4 ton housing into a GMC rear axle in my 59 Burb. I set it up as close to right as possible, and I still look over my shoulder for that fire truck siren that's following me around at times! Jerry
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Where do you buy the dial indicator to measure the backlash?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Ebay, Harbor Freight Tools, Northern Tool & Supply, Snap-On, Enco Tools, Goodson, and K-Line are all good places to shop for a dial indicator. A good one with the adapters you'll need to set up a rear axle will cost about $100.00. Jerry
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Thanks for the info. I hadn't thought about having a major noise problem with this. Considering I bought this 3rd member over the net I figured I was lucky that the guy was willing to send me the 4.10 gears when he could easily get away with shafting me. I'm out $265 now whether it works or not so I guess I'll just give it a shot and see what happens. Maybe I'll get lucky for a change.  <*)))><
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Are you getting a complete third member with the 4.10 gears? If so, you don't need to set anything. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you've never done it before, I would have a driveline shop set it up for you, Scott | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | Truckernix, I bought a 3rd member that was supposed to have 4.10 gears but when it arrived it had 4.57's. The guy is sending me some 4.10 gears to change out. 48bigtrucks, You're right, I think I'll take it to a pro. I don't mind tackling new things but I looked at the manual last night and it doesn't look real simple. Of course, the shop manual was written for people who alredy know what they're doing.
| | | | | Joined: Jun 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 47 | Inland Truck Parts and Service rebuilt my Eaton HO72 for about $250.00. Rearends are not cheap! At least I have peace of mind that it was done right.
Good Luck! Dan M. | | |
